Retro fit topbox brake light
kwarrrt1200
Post by kwarrrt1200 »
Hi all, hope this is a) in the right section... and b) NOT a numpty question??
I had to remove my top box & then remove the pillion seat pad and rear panel (the one with the BMW badge on), so I can do a minor paint touch up.
I found a wiring harness/plug under the rear panel - so I'm thinking I could add the BMW top box rear brake light.
Anyone else done this? It looks like (to someone who has just found the cable and NOT done any research.....) that its just a simple plug in and go?
Is it that simple... or am I - as usual - missing something really bloody obvious?
Bike is a 2017 model - UK based. Thanks in advance
Re: Retro fit topbox brake light
kwarrrt1200
Brilliant, thanks so much.
Totaled TL
Been liked: 9 times
Post by Totaled TL »
Way overpriced. $10 light from Amazon.
RC1200
Has liked: 3 times
Post by RC1200 »
Hi, have you got the detail of the top box brake light on Amazon? Or, anyone out there with a second hand light? £150 from BMW dealer is expensive! Cheers 👍
Has liked: 121 times
Been liked: 305 times
I ended up buying a new one as i could not find one secondhand.
But keep looking and i hope you find one :thumb:
RC1200
Has liked: 3 times
Post by RC1200 »
Has liked: 43 times
Been liked: 146 times
No need to spend £150+, for £5.81 you can have the same function, 10 minutes to fit with a soldering iron and 4mm drill.
Topbox light.jpg (206.32 KiB) Viewed 1952 times
RC1200
Has liked: 3 times
Post by RC1200 »
£5.81! Where from?
Has liked: 43 times
