Bypassing ABS
SamR1200rt
Bypassing ABS
Post by SamR1200rt »
MarkW
Bike Model and Year: R1200RT 2012
Been liked: 6 times
Re: Bypassing ABS
Post by MarkW »
That seems a rather dramatic approach. What problems exactly? Have you had it properly diagnosed? Fault codes read? It could be something as simple as a wheel sensor gone south or out of adjustment - have you done anything that could have impacted the sensor gap? Please tell us more.
These systems are pretty robust, almost (but not quite) as reliable as ABSII fitted to the 1100s prior to that god awfull servo system fitted to everything up to '07, which was unreliable and without the fail"safe" abilties of it's predecessor.
There were notorious issues with early versions of the system you have - incorrect tolerances in the brush holder meant the brushes would stick and not make proper contact causing the internal moter to fail. They could be fixed - I did a couple - but it requires getting inside the motor cover on the unit, something BMW didn't design for. I believe this had been addressed by the time yours was made. In any case it didn't affect braking, only ABS function, so bypassing the module doesn't really acheive anything as far as I'm aware.
MarkW
Been liked: 6 times
Re: Bypassing ABS
Post by MarkW »
Okay, ignore all that. Just seen your seperate thread on the same subject. Doh!
Has liked: 1154 times
Been liked: 307 times
Re: Bypassing ABS
No bypass is necessary. Just cover the flashing light on the dash. This is how my 07 has been for the last 5 years. Early models with the whizzy ABS needed a bypass kit
SamR1200rt
Re: Bypassing ABS
Re: Bypassing ABS
SamR1200rt wrote: Fri Jul 28, 2023 3:25 am.
