Hand grip aftermarket
- Has liked: 1 time
- Been liked: 9 times
I've been getting a painful callus at the base of my pinky from the throttle grip. I'm thinking of getting a thicker and softer replacement. Anybody know how hard it is to remove and replace the original hand grip, or if there is an aftermarket product that will fit over the existing grip? Thanks.
- Has liked: 8 times
- Been liked: 8 times
Re: Hand grip aftermarket
I have used foam rubber slip-on grips for all my bikes for years. They usually cost about $8 or $10 and slip on easily with a little liquid dish soap.
Tenequip
Tenequip
- Been liked: 284 times
Funny enough I put my grip puppies on yesterday.As Tenequip says,a little soapy water and they slip over the original grips no problem
Just measure and cut to the required length, soap em up and slide them on.
- Has liked: 422 times
- Been liked: 56 times
I used these, a bit thinner than puppies, might get another pair to try again
https://www.amazon.co.uk/gp/product/B09 ... UTF8&psc=1
- Has liked: 1075 times
- Been liked: 281 times
Every bike ive owned except an R80Rt( they had oblong grips) has had grip puppies fitted. If you have heated grips with GP slipped over them you will still feel the heat.
- Bike Model and Year: fjr1300 2006
- Been liked: 2 times
had them on my FJR for year - cured some high frequency vibrations nicely. putting them on he new 1250RT. they really do help reduce hand and finger fatigue on longer rides. also IMHO improve throttle control.
- Has liked: 1 time
Thanks, all. Are the regular Grip Pups OK for the RT, or will I need the "Big Paws"? Also, since the OD on the Beemer grips taper down towards the inside, will the GP's conform tightly, or do they gather a bit at the smaller end?
Just buy the normal puppies and they fit perfectly, as long as you measure and cut them correctly. I never went tight to the wheel,left a couple of mm gap and they look spot on.One thing I will say,cutting them with a Stanley blade pulled the sponge a bit,if I did them again I would get a long sharp blade and cut like a guillotine to give a sharper finish
- Has liked: 1 time
Bought some generic foam overgrips from Amazon. Used compressed air and small piece of tubing. No soap needed.
- Has liked: 1 time
Just installed the regular sized Grip Pup on the throttle and it feels great. It also fits tightly over the tapered thinner OD of the inboard side of the grip. Had to use WD 40 since the soapy water didn't cut it. Strange how the minimally greater circumference makes the throttle more sensitive and jumpy, which I suppose I'll get used to before long. Goodbye calluses, and I'm sure it will make longer trips less tiring and crampy for my right hand. Thanks for all the input.
"Strange how the minimally greater circumference makes the throttle more sensitive and jumpy, ..."
Shouldn't it have the opposite effect?
Your hands will get used to them quickly. At the moment you are just feeling hand and finger muscle memory.
Correction to my earlier post: Noticed that everyone is using soapy water when they install the grips, I use the liquid soak straight up no water added. Never had any trouble getting the grips with the liquid soap straight up.
Tenequip
Tenequip
- Steve398
- Has liked: 387 times
- Been liked: 315 times
There was a post on this site about a Chinese made ‘old RT’ type grip that really caught my fancy, so a I spoke to my specialist BMW mechie about it… pursed lips and an “Ooohh, be very careful” uttering quickly followed together with “they’re over a hundred quid if you get it wrong”
If he’s unhappy to do it then I certainly won’t… shame.
