Disconnecting battery
I've disconnected my battery on my new RT1250 to fit some accessories. Connected everything back up but the bike won't start. What could it be?
- Stu
- Has liked: 539 times
- Been liked: 487 times
Re: Disconnecting battery
Have you checked everything?
Is it in neutral etc
Disconnecting the battery and reconnecting it should stop it starting.
Check your connections too
Yea checked all connections. disconnected the accessories and put it back the way it was & still won't start.
- Stu
That suggests to me that the battery is not connected properly somewhere or the main fuse is popped
Pull the battery and check the polarity and also check the main fuse
Hi, can someone tell me where the main fuse is? I've looked online at the fuse box and can't see a "main fuse" listed. Thanks Pete
- Has liked: 1075 times
- Been liked: 281 times
no fuses. The bike uses canbus system
well blow me . I always thought everything was run by the canbus. My 07 has any fuses
- Been liked: 8 times
- Stu
