SOS icon and amber triangle on
Has liked: 488 times
Been liked: 81 times
Re: SOS icon and amber triangle on
Sorry to resurrect an old post especially as I started a new thread, but I had the triangle and sos warning light come on permanently yesterday on a ride out on my 2019 1250RT.
I’m hoping it was just a loss of signal, once I turned the ignition off and on it went away, reading this thread has me now thinking I’m going to end up with a flat battery if this telemetry module is constantly searching for satellites.
I’m guessing it’s not something that can be checked with a gs911 ?.
Actually is this a free sos service even when the warranty is up ?.
Has liked: 425 times
Been liked: 349 times
I had the warning triangle flashing on my first ride out after getting the bike. Bahnstormers at Alton arranged an appoint and did a software update within a week which solved the problem.
Has liked: 43 times
Been liked: 148 times
My bike went in for a 12k service and software update 5 weeks ago, I have been getting intermittent SOS warnings. Today on the Ride To The Wall I get it again, this time it doesn't clear. I guess I'll be calling Shrewsbury BMW on Monday, it's still under warranty for 11 more months.
GvG
Post by GvG »
Which SW update? Is it the "GS(A) transmission input shaft" SW update? You can check this by pulling the clutch in while riding and then give it full throttle, it won't rev higher than 6000 rpm where as before you would hit the revlimiter.
Has liked: 43 times
It revs past 6k fine. When it was booked in for the 12k service they asked to have it for 2 days as it would need a software update, no idea as to what it was for.
GvG
Post by GvG »
Glenn wrote: Sun Oct 08, 2023 8:46 am It revs past 6k fine.
Did you check this with the clutch pulled in?
Has liked: 43 times
GvG wrote: Sun Oct 08, 2023 7:11 pm Did you check this with the clutch pulled in?
Clutch pulled in also when riding the bike.
Has liked: 43 times
SOS light is back on, so I'll call Rybrook BMW in Shrewsbury tomorrow.
Has liked: 43 times
Called Rybrook today, the bike is going in for investigation tomorrow
Has liked: 43 times
BMW replaced the SOS switch today, just need to see if it's resolved the problem by riding the bike.
