Rear Tyre
Has liked: 121 times
Been liked: 305 times
Rear Tyre
I know the RT uses a 180/55/17 on it 5.5" rim.
Now i have fitted a 190/50/17 to a 5.5" rim before and never had any problems.
I have a brand new 190 tyre that was for my Hayabusa, but its now sold.
So can i fit the 190 on the RT ?
Will the ABS ect ect ect be ok with the 190.
Has liked: 559 times
Been liked: 519 times
Re: Rear Tyre
I suspect it will be the aspect ratio that would make any difference
Ie the 50 or 55 as this is the height of the tyre
Although the abs will have an element of error in it anyway
But the abs on these bikes uses a ring with gaps in it to detect if the wheel has stopped or not
It's the traction control that senses wheel speed from the abs sensor and makes sure ones isn't moving faster than the other
Has liked: 1152 times
Been liked: 306 times
Re: Rear Tyre
May touch the swing arm
