BMW R1200RT Cam alignment tools
Re: BMW R1200RT Cam alignment tools
Hi,
Are the tools that you bought compatible with 2018 BMW RT? I am very interested in buying them too, but before I place the order I want to ensure they are the right ones for my motorbike. It would be a costly mistake otherwise.
Many thanks in advance,
Pano.
Pano.
- Has liked: 484 times
- Been liked: 81 times
There is a difference between the 1200 and 1250 camshaft alignment jigs, also the collar that is used with the cam chain tensioner tool is a different length. Your friendly ( not necessarily local) bmw dealer should be able to sort this for you.ptoundas wrote: ↑Tue Dec 26, 2023 2:19 am Hi,
Pano.
- Has liked: 1152 times
- Been liked: 306 times
Just seen you can now buy part 83302327790 - alignment pin tool from Aliexpress for £25 inc shipping.
I wouldnt exspect it to be OE part at that price but if it's true to image it looks well made
Thanks for the heads up, I got the alignment pin last year, also the cam alignment jigs arrived for the 1250 motor, the last bit of the jigsaw ( cam chain tensioner tool) is supposed to arrive this month !!.
I was actually expecting to have sold the rt before it arrived !,
- Stu
- Has liked: 559 times
- Been liked: 519 times
Found them all on AliExpress.
TDC tool and Cam alignment tool: https://www.aliexpress.com/item/1005006449041265.html
Manual cam chain tensioner: https://www.aliexpress.com/item/1005005797966751.html
Engine turning tool option 1: https://www.aliexpress.com/item/1005006445576962.html
Engine turning tool option 2: https://www.aliexpress.com/item/1005006069166399.html
Expecting delivery any day now. I think they will work just fine, and the price is right...
