Location of Can-Bus Plug
NoGoodID
Bike Model and Year: 2023 1250RT
Has liked: 5 times
Post by NoGoodID »
Hi. I have a 2023 1250 RT, and want to power an accessory (i.e., a usb charger that I’ll keep in my tank bag) by connecting it to the Can-Bus system, so that the power to the accessory turns off when the bike is off. I bought this pigtail (see photo), but am not sure where the Can-Bus connector is located on the bike. Anyone know?
Has liked: 121 times
Been liked: 305 times
Re: Location of Can-Bus Plug
When i fitted all my accessory, I avoilded connecting anything into the Can-Bus system.
I fitted a fuse box and 40amp relay that is powered from the battery.
I just used the time delay switch-live on the bike.
So all my accessory that are connected turn off after 60sec if i forget.
I fitted the fuse box behind the right speaker panel as i dont have a radio.
It makes it easier to change a fuse if needed and its out the way.
Gareth1962
Been liked: 5 times
Post by Gareth1962 »
Hi,
Done exactly the same thing on a 2021 RT.
Looking down in front of the tank on left hand side (as when sat on bike) just under the bottom of the cubby hole, you will see some wiring all clipped in. Amongst that you should also see a blanked off connector (black), cabled tied to the loom.
Carefully !!!cut the cable tie to free it it up.
Going to assume nothing changed on 2023 version!
Works a treat for me
Hope this helps
G
2021 R1250RT LE Blue
exportman
Has liked: 9 times
Post by exportman »
I piggyback the switched feed from the accessory socket ( front or rear) to a relay and a fused power feed direct from the accessible positive battery terminal.
NoGoodID
Has liked: 5 times
Post by NoGoodID »
Gareth1962 wrote: Sun Feb 25, 2024 8:48 am Hi,
Hope this helps
G
Thanks Gareth1962! Very helpful!
NoGoodID
Has liked: 5 times
Post by NoGoodID »
exportman wrote: Sun Feb 25, 2024 10:53 am I piggyback the switched feed from the accessory socket ( front or rear) to a relay and a fused power feed direct from the accessible positive battery terminal.
Thanks exportman. If (when) I have any other accessories to add, I plan to tap into this pigtail for switched power, and then add some sort of fuse block (like a PDM60 or Fuzeblock) directly connected to the battery. I think you are saying that’s what you did. Right?
Has liked: 559 times
Been liked: 519 times
NoGoodID wrote: Sun Feb 25, 2024 2:58 pm Thanks exportman. If (when) I have any other accessories to add, I plan to tap into this pigtail for switched power, and then add some sort of fuse block (like a PDM60 or Fuzeblock) directly connected to the battery. I think you are saying that’s what you did. Right?
If that's what you ware going to do then use the accessory plug to operate a relay to turn on the fuze block rather than splicing in to wiring
That way it will shut off after 30 seconds too
NoGoodID
Has liked: 5 times
Post by NoGoodID »
sakm wrote: Sun Feb 25, 2024 5:06 pm If that's what you ware going to do then use the accessory plug to operate a relay to turn on the fuze block rather than splicing in to wiring
Thanks. I may not have been clear, but yes that’s what I intend to do. I will tap into the yellow pigtail in pic above, so that it serves as the relay to know when the bike is on/off. The power will come from the fuzeblock (or PDM 60), that will be connected to the battery.
NoGoodID wrote: Sun Feb 25, 2024 7:06 pm Thanks. I may not have been clear, but yes that’s what I intend to do. I will tap into the yellow pigtail in pic above, so that it serves as the relay to know when the bike is on/off. The power will come from the fuzeblock (or PDM 60), that will be connected to the battery.
Nope you was clear enough I just miss read it :lol:
NoGoodID
Has liked: 5 times
Post by NoGoodID »
sakm wrote: Sun Feb 25, 2024 7:08 pm Nope you was clear enough I just miss read it :lol:
exportman
Has liked: 9 times
Post by exportman »
Yes that's what I did I didn't have radio on my 16 bike so I put the fuse box in the speaker pod on the right worked perfectly for 7 years then early last year I changed the bike for a new one.
djk63
Bike Model and Year: 2024 R1250RT
Post by djk63 »
I just brought home my new 2024 R1250RT and getting power to my Zumo XT2 is a priority. I bought the pigtail adapter the OP showed but the Canbus plug is nowhere to be found near the left fork, or right for that matter. Does anyone have knowledge that it’s actually there on a 2024?
djk63
Post by djk63 »
Cancel that. I did some more digging and it was tucked up out of sight on the left. I must have looked at it 5 times before and didn’t see it :(
