r1250rt handlebar width
- Bike Model and Year: RT1250 2021
- Has liked: 1 time
- Been liked: 3 times
Hi all. In the process of picking up my new to me 1250 and I need a set of Canyon Dancers as I will be traiiering home. Does anyone know the handlebar width of the RT? Seems Canyon Dancers are available in a number of different widths.
- Bike Model and Year: R1250 RT LE 2019
- Has liked: 15 times
- Been liked: 14 times
Re: r1250rt handlebar width
Hi. Just in case you are not aware but it is not recommended to tie an RT down by the handlebars at all. I remember reading something a few years ago that it damages the front suspension. The tie down point is to wrap around each fork just above the bottom fork clamp. That gives a solid tie point but does not damage the bars and suspension. The rear ties go behind the rear foot pegs onto each bracket. Hope this helps.
- Has liked: 1 time
Thanks so much for the tie-down tip. The attached diagram is especially informative. Will be using standard ite downs attached to the fork legs.
