r1250rt handlebar width
frogor
Bike Model and Year: RT1250 2021
Post by frogor »
Hi all. In the process of picking up my new to me 1250 and I need a set of Canyon Dancers as I will be traiiering home. Does anyone know the handlebar width of the RT? Seems Canyon Dancers are available in a number of different widths.
Mac001
Has liked: 15 times
Been liked: 14 times
Re: r1250rt handlebar width
Post by Mac001 »
Hi. Just in case you are not aware but it is not recommended to tie an RT down by the handlebars at all. I remember reading something a few years ago that it damages the front suspension. The tie down point is to wrap around each fork just above the bottom fork clamp. That gives a solid tie point but does not damage the bars and suspension. The rear ties go behind the rear foot pegs onto each bracket. Hope this helps.
Has liked: 121 times
Been liked: 305 times
Here you go.
Tie Down Points.jpg (55.27 KiB) Viewed 1001 times
frogor
Post by frogor »
Thanks so much for the tie-down tip. The attached diagram is especially informative. Will be using standard ite downs attached to the fork legs.
