Drilling holes in screens !
jesim1
Has liked: 120 times
Been liked: 74 times
Post by jesim1 »
I fitted a Power bronze touring screen to my 22 RT and felt that although it was better than the original, the added size meant I was getting a bit more forward suction from the low pressure area that builds up behind the screen. My solution was to drill 4 x 13mm hols in the screen to see if this helped - and it did, there is no down side to this, the holes are small enough so as not to affect the strength of the screen, kept away from stress points, and there is no wind noise, which was a concern, best of all ....... it works, and there is now less pull than on the OEM screen :P
Has liked: 1152 times
Been liked: 306 times
Re: Drilling holes in screens !
That's why bikes like the Gold wing had a vent. I was thinking of putting a Goldwing vent in my screen
jesim1
Post by jesim1 »
Doctor T wrote: Tue Mar 19, 2024 3:48 pm That's why bikes like the Gold wing had a vent. I was thinking of putting a Goldwing vent in my screen
I just could not find a screen that had these for the R1250RT when I was looking for one I liked, I had one on my last bike with the vent and it solved the problem:
Jeffem
Has liked: 29 times
Been liked: 21 times
Post by Jeffem »
Wow, that’s a brave move. Not sure I would have the balls to drill holes in my screen. Respect. :cheers:
How much bigger is the Powerbronze screen compared with the OEM?
Slow in, fast out.
jesim1
Post by jesim1 »
Mine looks like a couple of inches taller and a different shape at the sides, it does not look much when next to each other, but there is a big difference the way the air is directed over and around you, for the money I paid for it (new) it was a bargain, I'd buy another in the future.
Has liked: 559 times
Been liked: 519 times
I have the same screen and it's actually half an inch taller at full height!
But the shape makes the air flow better in my opinion
I think it's the right size and the air management is good
jesim1
Post by jesim1 »
sakm wrote: Wed Mar 20, 2024 1:45 pm I have the same screen and it's actually half an inch taller at full height!
I can't remember, I'm going for memory, but I think you can get the OEM screen in different sizes, and also the Powerbronze ones, mine is the 700mm version.
jesim1 wrote: Fri Mar 22, 2024 8:34 pm I can't remember, I'm going for memory, but I think you can get the OEM screen in different sizes, and also the Powerbronze ones, mine is the 700mm version.
Ah!
There is only one for the 1200
Screenshot 2024-03-22 203720.png (188.39 KiB) Viewed 4254 times
