Foot peg lowering kit for RT
- Has liked: 14 times
- Been liked: 83 times
Re: Foot peg lowering kit for RT
Another one with a smug look on my face for buying a Far East copy and not the well known brand rip off.
If you are going to go down this route a few tips.
1. Watch the Wunlerlich video on how to fit them a couple of times. It's a really good step by step explanation.
2. The footpeg pins that you have to drive out corrode and seized up. Several doses of penetrating oil applied over the preceding days will make it easier, but even then I suspect if your bike is a few years old you'll still end up hitting it with a big hammer & drift. Grease with waterproof grease before reassembly.
3. You'll need a T47 Torx bit (and an extension) to reach the bolt holding the RH footrest plate on. That size didn't feature in any of the sets I had and I had to order one.
4. The return spring for the hinged footrest is a real sod to put back on. The aforementioned video shows it just clipping into place with a little bit of help from screwdriver. Me, I swore & cursed.
4. Mark sure you've got a few spare circlips for the pins. One of mine went ping when I took it off and hasn't been seen since.
5. Lastly, the lowering kit pushes your feet out a little wider. Personally I found this added to the comfort but it does move your feet away from the foot controls. It doesn't seem to matter on the gear lever side, but I found the rear brake lever no longer fell in the right position for my foot. After a bit of assuming I'd just get used to it, I didn't. In the end I ordered a brake lever extender to make it right, and they're not cheap, £60 from N.N. AND because you've added a little height to the brake lever you have to lower it just a little to restore the right height.
- Been liked: 321 times
Well I never bought a big enough box spanner so that idea is on hold.Im of to Scotland Tuesday and need to get something sorted.Tried allsorts to no avail,then the bulb flickered.I tried the jack handle sleeve,bit flimsy but with a bit of tape and securely clamped on,i give you,,,,,,,,,,bodge MK1
Not a long term fix but if it gets me to Scotland and back its a winner and something to build on
- Steve398
- Has liked: 417 times
- Been liked: 342 times
It sounds like you were there in the garage with me… what a copper-plated bi*ch it was to do that spring, and how I laughed when I re-viewed that video, plus I never did find the circlip!Capt Sisko wrote: ↑Fri Jun 23, 2023 11:19 am
Been out on zee bike and can go up and down the box so much better.Changing boots has also helped,little tweaks should make it spot onburridge01 wrote: ↑Sat Jun 24, 2023 6:17 pm Well I never bought a big enough box spanner so that idea is on hold.Im of to Scotland Tuesday and need to get something sorted.Tried allsorts to no avail,then the bulb flickered.I tried the jack handle sleeve,bit flimsy but with a bit of tape and securely clamped on,i give you,,,,,,,,,,bodge MK1
- Has liked: 474 times
- Been liked: 76 times
When I win the lotto I’m buying an 1800 wing,,. The bike I’ve always wanted!.burridge01 wrote: ↑Sun Jun 25, 2023 11:29 am Been out on zee bike and can go up and down the box so much better.Changing boots has also helped,little tweaks should make it spot on
G'day just wondering if anyone has a link to the aliexpress footpeg lowering kit for a 2010 1200 RT. Only seem to find them for later models.
Cheers
Cheers
Ok just fitted the kit and a few things of note.
Adjusted gear lever to suit my foot and checked I could engage 1st gear without engine running, soon as running and rolling I can no longer get 1st gear, nothing is fowling but after raising the lever some I can now gear gears but it’s not perfect for my foot position ?.
Footing the bike up my ramp out the shed I found the pegs in the way as they are wider.
On the go it’s definitely better for my knees with the seat in low position.
It’s unlikely but do you think re learning the quickshifter with the gs911 may improve the manual selection of 1st gear ?.
That's exactly what happened on mine,hopefully you've now sorted it
It’s funny how something so trivial can catch you out , I think it’s all ok now though, I did drop the lever a tad more and filed off some more of the side stand foot but didn’t go out again.burridge01 wrote: ↑Fri Jun 07, 2024 1:00 pm That's exactly what happened on mine,hopefully you've now sorted it
Did you re learn the quickshift ?, I don’t think it’ll make any difference.
I have an injury to my left leg,so I've had to relearn the whole changing gear in any fashion
You must of been like me,I filed mine down(sure I posted at the time)Got down to the M25,pulled over onto the hard shoulder,unbolted it and lobbed it into the verge Live and learn
Found it
viewtopic.php?t=7253
And you read it
Found it
And you read it
, i vaguely remember that now!, almost a year ago but i have trouble remembering what happened last week .burridge01 wrote: ↑Fri Jun 07, 2024 8:37 pm I have an injury to my left leg,so I've had to relearn the whole changing gear in any fashion
Found it
And you read it
I didn’t take mine off, just used a round chainsaw file to take out half round chunk then painted with black. I may remove it as sometimes I find it difficult to get the stand down when the wife’s on the back, having to lean slightly over to the right isn’t a natural thing with all that weight of us and the bike .
So twice now since fitting the peg lowering kit to the 1250RT I’ve managed to to stall the motor when trying to put the side stand down . Looking for the stand with my boot heel I’ve inadvertently tapped the gear lever into 1st !. Obviously not good for either the gearbox and embarrassing if anyone is close by.
Yesterday when we went out i concentrated on switching off before the side stand but found that not always easy depending on where parked,
Anyone else done this ?.
- EasyRider
- Has liked: 121 times
- Been liked: 305 times
yep, 2 times so far. both times i was in my driveway. I now turn the bike off first.
