Stalled on highway
staller
Netherlands
Stalled on highway
Post by staller »
Hello Everyone,
I bought used 2005 R1200RT on the 20th of June.
Mileage was 53.000 km. The seller told me the motorcycle was serviced a week ago and can be driven 10.000 km until the next service. Only issue was the fuel tank indicator (fuel strip) (it does not show the correct value)
The same day I bought the motorcycle, it was stalled on a busy highway and it was scary.
Here is what was happened in chronological order
- I have filled the tank full (95 octane unleaded) (vendor was BP)
- I was driving the motorcycle on the highway as usual.
doing 80-100 km/hours around 4000-5000 RPM
Occasionally there was a smell of a rich mixture of exhaust gas. I did not pay attention too much at that time because I did not know what was the source, I thought maybe it was coming from other vehicles.
- After driving it ~25 km, engine stalled without any error indicator on display
Motorcycle come to a stop
I turned the ignition off, waited a little and tried to start the engine.
Engine got started but quickly choked and stopped (tried 2-3 times and the result was the same)
- Road service put the motorcycle nearest safe parking spot
The motorcycle parked outside for 1 hour
After 1 hour I have tried starting it, this time engine run without stalling
I let it run on idle for 1 minute
Then I switched ignition off
I decided to give it a test drive
After riding it for 2-3 km and 5 minutes, the engine stalled again (without any fault indicator)
As happened before,
I turned the ignition down, waited a little and tried to start the engine.
As a last resort, I have tried revving the engine
After igniting it I have quickly revved it to 5000 rpm, this time engine did not come to a stop and I kept 5000 rpm for ~20 seconds
The outside temperature was around 16 Celcius
While revving it I saw from the mirror there was a white smoke at the exhaust
I let loose throttle, engine could able to keep it on idle
Without stopping the engine, I give it a test drive
After riding it for 5 minutes the engine stalled again and this time revving it did not help.
This was the last event
The motorcycle is now at an official dealer service. What could be the reason since this was a seriously dangerous thing to happen I am in fear if this would happen randomly in the future.
Thank you.
Has liked: 559 times
Been liked: 519 times
Re: Stalled on highway
Could easily be a blocked tank breather stopping fuel flow
staller
Netherlands
Post by staller »
Here is the roadside video of stalling after it stalled on highway.
staller
Netherlands
Post by staller »
sakm wrote: Thu Jul 11, 2024 11:55 am Could easily be a blocked tank breather stopping fuel flow
Can this happen if the fuel tank cap did not properly fit (clicked locked) after fueling it?
Am asking because I might did not properly press it down, I only realized after motorcycle pulled to another place and when I have checked the cap it was a little popped up and after I pressed it down firmly it clicked.
staller wrote: Thu Jul 11, 2024 12:12 pm Can this happen if the fuel tank cap did not properly fit (clicked locked) after fueling it?
No
That would actually help matters as it would allow air in to the tank
A blocked breather would cause a vacuum and stop the fuel flow. An easy check is to ride it till in stops then open the tank and if all is good after that then there is your answer.
staller
Netherlands
Post by staller »
This turned out of corroded fuel pump controller, the bmw service also changed fuel pump as well. Now everything works as expected.
staller
Netherlands
Post by staller »
I have also made myself a bypass cable from the remains of the corroded controller
