Hi
Can I have some advice please?
R1250RT 2021 on a trip this morning. Had to stop after an hour of fast A roads and then it wouldn’t start. Barely turning over and wouldn’t catch. Volts reading as 12.0.
I tried it a couple of times and it was the same. Left it 20 minutes and it started fine.
Any help appreciated…
What happened? Wouldn’t start
- Bike Model and Year: R1250RT 2021
- EasyRider
- Has liked: 113 times
- Been liked: 282 times
Re: What happened? Wouldn’t start
It could be the same hot starting problem as some of the 1250GS.
I think they replaced the starter solenoid or cleaned the contacts.
Have a look on UKGSer.
- michaelc2710
- Has liked: 50 times
- Been liked: 63 times
Hi
You will probably find it's the battery.
They had a problem around 2020-2021 of batteries getting warm and internally shorting, once left to cool down it would start again.
It's the start of it giving up, there was a batch / battery number that was effected but I can't remember it now.
Do a search on here and you should find it.
- Been liked: 379 times
This thread may be helpful, viewtopic.php?t=6039&hilit=compression
