Starting in 1st
slparry
Has liked: 12 times
Been liked: 31 times
Starting in 1st
Post by slparry »
Can someone do a sanity check for me as I'm sure my R12RT LC used to start in first with the clutch pulled in, it's now only starting if I put it into neutral.
I have several bikes, plus I work with bikes so I'm not sure if I'm misremembering :D
Steve Parry, Triumph Chester, current toys '15 R1200RT LE Dynamic. '14 F800GS ,'03 R1100S Boxercup, '85 R80RS Mono, '90 K1, '05 K1200S
Has liked: 554 times
Been liked: 511 times
Re: Starting in 1st
You need a new clutch switch!
I have just replaced mine for the same issue
slparry
Has liked: 12 times
Re: Starting in 1st
Post by slparry »
thanks Stu, you've confirmed my suspicion
7vwh
Has liked: 16 times
Been liked: 40 times
Re: Starting in 1st
Post by 7vwh »
Stu wrote: Mon Aug 19, 2024 4:45 pm You need a new clutch switch!
Part number and process please 🫶
Re: Starting in 1st
7vwh wrote: Tue Aug 20, 2024 10:20 pm Part number and process please 🫶
Depends on if you have cruise control or not
And it's just one screw to swap it
I will post more when I'm not in bed 😂
7vwh
Has liked: 16 times
Re: Starting in 1st
Post by 7vwh »
Stu wrote: Tue Aug 20, 2024 11:46 pm Depends on if you have cruise control or not
I have the cruise control. I’ve been putting it off changing it for a while 😂
Re: Starting in 1st
7vwh wrote: Wed Aug 21, 2024 6:59 am I have the cruise control. I’ve been putting it off changing it for a while 😂
This is the one you need then
https://www.motorworks.co.uk/clutch-mic ... 609-1.html
BMW dealer was going to charge me £55 which is a good price but for ease I just got one delivered with my service kit
There is a small T8 screw that comes out then the switch will come off and fitting is reverse of removal (I sound like Haynes)
There is a locating peg for it to go in to too so just make sure it's in that
7vwh
Has liked: 16 times
Re: Starting in 1st
Post by 7vwh »
Cheers Stu 👍
