Best oil for your bike
Been liked: 379 times
Re: Best oil for your bike
How about this one from OPIE Oils, https://www.opieoils.co.uk/p-90213-motu ... e-oil.aspx it exceeds the BMW spec. for a Camhead.
lancashirert
Has liked: 33 times
Been liked: 14 times
Post by lancashirert »
David. wrote: Sun Aug 25, 2024 8:21 am Looking at this video reminded me of the following. As per the BMW Rider's Manual, the engine oil spec. is API SF / ACEA A2, or better, with various viscosity ranges based on the ambient temperature. No mention of JASO MA or MA2 for wet clutches. The 2012 Camhead has a car like dry clutch. The BMW Motorrad ADVANTEC Pro oil spec. is SAE 15W-50, API SJ / JASO MA2. Why pay more for a wet clutch oil when it is not required. Has anyone used a car oil in their dry clutch RT.
Forgive my ignorance on oil specs, but how does one know if an oil spec is better or worse than the manufacturer recommended please? Thank you.
The oil spec. for a Camhead is API SF / ACEA A2 or better.
The spec. of the Motul oil linked above is API SN / ACEA A3.
Quico
Has liked: 6 times
Portugal
Post by Quico »
yeap. I use car oil. Shell Helix hx7 10w40 same as Shell Advance AX7 for bikes but without JASO MA2.
it exceeds all requirements stated on my 2010 camhead user manual.
Castrol GPS SAE 10W-40, API SG / JASO MA ~-20 °C
SAE 5W-40, API SF / ACEA A2, ou superior ~-20 °C
SAE 5W-~50, API SF / ACEA A2, ou superior ~-20 °C
SAE 10W-40, API SF / ACEA A2, ou superior ~-10 °C
SAE 10W-~50, API SF / ACEA A2, ou superior ~-20 °C
SAE 15W-~40, API SF / ACEA A2, ou superior ~0 °C
