North East 250 (Scotland)
Have you got a decent route to share with us? please post it here along the the gpx file for others to download and enjoy. We would love to hear about your best biking roads and routes.
Recently came across a link to the North East 250 (in Scotland), https://www.northeast250.com/see-the-ro ... OS4wLjAuMA..
Have created a BaseCamp circular route from Ballater which is 220 miles. The start/finish point is 30 miles away on the A93, just south of the Devil's Elbow Viewpoint which would make it 250 miles.
Haven't done much around the NE of Scotland, might be one for the future.
LochiesDad
Been liked: 8 times
Re: North East 250 (Scotland)
Post by LochiesDad »
I do appreciate this is an old post however this is a great route and i'd be more than happy to organise a run if there's an appetite for it?
Have found the route in my Garmin Basecamp collection.
If you can organise the weather, I'd "consider" doing it.
Has liked: 43 times
Been liked: 146 times
I spent 12 years up at Kinloss in the 80's & 90's, get off the main roads and it's great touring
jesim1
Has liked: 120 times
Been liked: 74 times
Post by jesim1 »
I think next year would be worth looking at, I'm in central Scotland, and unless it stays dry for several days now the roads are staying damp to wet. I don't see this changing much till next year, so I'll be restricting my trips to more local roads and where I can do a run without any planning to take advantage of any breaks in the weather.
If anyone has the gpx file I'd be happy to have a look at it ;)
James
jesim1 wrote: Sun Nov 17, 2024 1:28 amIf anyone has the gpx file I'd be happy to have a look at it.
PM me an email address and I'll send you my version of the route.
Has liked: 559 times
Been liked: 519 times
David. wrote: Sun Nov 17, 2024 7:47 am PM me an email address and I'll send you my version of the route.
You should be able to attach a gpx of the route to a post or pm :thumb:
Does this work.
NE 250 Route.gpx
(1.23 MiB) Downloaded 32 times
Well it's attached
I downloaded it and opened it up in MyRoute-app and it had a few waypoints
It only showed straight lines though but that's down to it not being re calculated by MyRoute-app
When sharing routes, I find that it's best to keep them in the Garmin BaseCamp .gdb format and email to each other.
Converting to/using alternative route planning software usually screws them up.
Stu wrote: Sun Nov 17, 2024 9:37 amI downloaded it and opened it up in MyRoute-app and it had a few waypoints.
Can you make any sense/use of this MyRoute-app route, https://www.myrouteapp.com/en/motor-and ... Cairngorms
"You can download the route for free without MyRoute-app account. To do so, open the route and click 'save as'."
David. wrote: Sun Nov 17, 2024 1:08 pm Can you make any sense/use of this MyRoute-app route, https://www.myrouteapp.com/en/motor-and ... Cairngorms
Works fine for me and I can download it in any format I want
David. wrote: Sun Nov 17, 2024 12:33 pm When sharing routes, I find that it's best to keep them in the Garmin BaseCamp .gdb format and email to each other.
That's because you're not using enough waypoints
Each software has its own way of calculating routes and this includes basecamp depending on how the user has it set
Not everyone uses basecamp so not everyone would be able to use a route from it
Putting plenty of waypoints in avoids route differences and exporting to gpx means anyone that wants to use it will get the same route
Best way if sharing routes for a ride out so everyone has the same route
Stu wrote: Sun Nov 17, 2024 4:46 pmThat's because you're not using enough waypoints.
I'm using enough waypoints and shaping points in Garmin BaseCamp to create my bespoke route and use it successfully with my Garmin Zumo 660.
If I join the 2 routes to create the full NE 250, then create a track, the track has 3,531 points.
David. wrote: Sun Nov 17, 2024 5:04 pm I'm using enough waypoints and shaping points in Garmin BaseCamp to create my bespoke route and use it successfully with my Garmin Zumo 660.
if you want to share routes you need to think others and their needs
Not everyone uses basecamp and not everyone uses garmin
If you want to create a route that everyone and everything can use then waypoints is the way to go not shaping points and not garmins own format.
I regularly create routes for use on 3 different garmin 3 tomtoms 1 bmw navigator and 1 other app depending on what he is using at the time. All my routes work on all these devices without differences using waypoints
