0-4000rpm PING
havnfun61
Re: 0-4000rpm PING
Post by havnfun61 »
Thanks for the input.I have gearshift pro and yes it does show the "up" arrow below 4K rpm.I turned it off.Yes a slow roll on below 4K rpm =no ping.I have been changing the way I ride,can't crack the throttle from a stop.gentle roll on then spirited.Hurts me every time.Thanks again
Cleverbee
Re: 0-4000rpm PING
Post by Cleverbee »
Little Arrow ????
If I use the GSP when in Dynamic mode and engage Warp Drive, I tend not to be looking at the instrument panel.........  :not speak:
BeeJay
Re: 0-4000rpm PING
Post by BeeJay »
I have GSP on my Sept 14 bike.
What little "arrow" are we talking about?
guest3074
Re: 0-4000rpm PING
Post by guest3074 »
Cleverbee wrote: Little Arrow ??? ?
You can set the bike to show a green up arrow next to the gear indicator to say when the bike thinks you should change up a gear  ;)
mhr43
Re: 0-4000rpm PING
Post by mhr43 »
My local BMW dealer told me the 'pinking' type noise was from the cam chain tensioner and nothing to worry about!
Levisp
Re: 0-4000rpm PING
Post by Levisp »
mhr43 wrote: My local BMW dealer told me the 'pinking' type noise was from the cam chain tensioner and nothing to worry about!
Maybe he's referring to the cam chain rattle at start up. When you first start the bike you can hear a rattle that only lasts for a few seconds. The cam chain tensioner uses oil pressure to tension the chain.
BeeJay
Re: 0-4000rpm PING
Post by BeeJay »
Sorry, getting back to the little green arrow.
I can find no reference to this in my riders manual.
Is it standard with shift assist?
guest3074
Re: 0-4000rpm PING
Post by guest3074 »
BeeJay wrote: Sorry, getting back to the little green arrow.
Got into the menu and Settings\Vehicle\Shift Indicator
No idea if it is model specific.
Levisp
Re: 0-4000rpm PING
Post by Levisp »
Turned mine off, it just annoyed me. If I remember it wants you to shift up far too early. Another gimmick IMHO.
BeeJay
Re: 0-4000rpm PING
Post by BeeJay »
Many thanks.
It was set to "off" which is why I never saw the arrow.
It will be interesting whether I find it of any value.
Worth a try.
Re: 0-4000rpm PING
Remember its throttle responsive.  Ride hard it will indicate later and vice versa.
BeeJay
Re: 0-4000rpm PING
Post by BeeJay »
Found it.
Very strange, was in 4th and about to change down and the arrow was suggesting upshift.
Don't think I'll bother with it.
Do I really need telling when ton change gear? I think NOT.
Thanks for the info[size=78%].[/size]
Levisp
Re: 0-4000rpm PING
Post by Levisp »
Sounds like you were as impressed as a Euro debate.
Re: 0-4000rpm PING
You have to ask why they would install it if it gives you false info all the time.  And as its been there for over 2 years now why haven't they done an update to "fix" it.
Must admit mine was turned off as soon as I discovered how to.
havnfun61
Re: 0-4000rpm PING
Post by havnfun61 »
Thanks again to all who responded.The latest from BMW tech is....the cams have a compression release lobe that is engaging.He thought that is what I'm hearing.I know S&S builds cams like this for big displacement Harley engines but did not know BMW was doing it.I'll just keep pounding on it.Thanks again
