Final drive centre hole bung and heat ?
Has liked: 424 times
Been liked: 348 times
Re: Final drive centre hole bung and heat ?
Panman40 wrote: Sat Jul 08, 2023 3:00 pm I’ll wait until you sell me that Werx Steve :-D
Don’t hold your breath… :-D
Has liked: 484 times
Been liked: 81 times
Steve398 wrote: Sat Jul 08, 2023 4:36 pm Don’t hold your breath… :-D
I’m not!
burridge01 wrote: Wed Jul 05, 2023 4:33 pm Perfect fit.
Dumb question… which side is which ?, just got mine :lol:
Bike Model and Year: NUFFINK
Been liked: 327 times
The bigger piece in the wheel side.Top tip,push it through from the driveshaft side and do it up from the wheel side,it's a pain trying to do it the other way.And I used a pair of long nosed plyers to tighten it up with a dab of medium thread lock.Who knows if I'll be able to get it off :mrgreen:
burridge01 wrote: Wed Jul 19, 2023 3:09 pm The bigger piece in the wheel side.Top tip,push it through from the driveshaft side and do it up from the wheel side,it's a pain trying to do it the other way.And I used a pair of long nosed plyers to tighten it up with a dab of medium thread lock.Who knows if I'll be able to get it off :mrgreen:
Thanks, I was trying to do it that way but it didn’t seem to sort itself on the final drive side, did you take out the plastic seal then fit the thingy or fit the thingy with the seal in place ?. :?:
It's a right bugger as I found out when you try and do it from the driveshaft side because as you say,you have to split the seal(into 2 parts with the rubber ring staring at you :mrgreen: )
I put that all back together and undid the wheel side from the rod,much easier.Mine sat in the orifice nice and snug then I just attached the wheel side and made tight with the long nosed plyers.
burridge01 wrote: Wed Jul 19, 2023 6:34 pm It's a right bugger as I found out when you try and do it from the driveshaft side because as you say,you have to split the seal(into 2 parts with the rubber ring staring at you :mrgreen: )
Mmm, maybe mines difference, I noticed the smaller side was in 2 halves so kept that screwed up tight, I can’t get it to slide through the oe plastic ring seal though, seems it’s only the o ring stopping it pulling through the centre tube. Dunno :lol:
Try loosening the smaller bit and then push it in,just hold it when tightening up.When I worked out not to split the smaller section it went in a piece of pish :thumb:
Well the one I received just isn’t long enough to attach both caps! :lol: , had a good look today outside the cramped shed and just now way it’s going to reach . Mines a 1250 so I don’t know if there’s a difference but not that I’m aware of.
Quick put in the for sale section :mrgreen:
burridge01 wrote: Thu Jul 20, 2023 5:48 pm Quick put in the for sale section :mrgreen:
:lol:
Has liked: 72 times
Been liked: 71 times
Post by Sullivj »
Fitted mine to my 2012 bike yesterday. Not convinced I have it in the right way around, or if there is a 'right' way, as both discs will pass through the center hole...
Anyway, it's on and looks nice!
Mines for sale, well postage at cost to anyone who wants it 👍
Fourbears
Been liked: 6 times
Post by Fourbears »
Ok how much is postage?
