2015 R1200RT - programming FM Stations ???
NoVaBob
Post by NoVaBob »
The Germans must've had help from the KIA or Nissan writing the instructions for programming FM stations manually.  Trying exactly as written (and several other keystroke attempts), I can't get the MODE button to give me  FM + MAN on the display for multi-controller access to stations.  Is it multi-touch, or hold it down, or ......?
OrangeOkie
Re: 2015 R1200RT - programming FM Stations ???
Post by OrangeOkie »
bump.
I too am stumped.  Any help appreciated
Whatsoever thy hand findeth to do, do it with thy might; for there is no work, nor device, nor knowledge, nor wisdom, in the grave, whither thou goest. - Ecclesiastes 9:10
JayCee
Post by JayCee »
Once you get FM AS showing, press mode button and display changes to FM mem, press mode again and it changes to FM man. Normal press and release.
AussieRT
Post by AussieRT »
I have a some what related question, when you have it in Manual mode can you increment the station number manually, eg move it from 97fm to 97.5, 98 etc. because when I move the wheel to the right or left it auto seeks the next station which goes past the station number I want to set.
thanks
2015 R1200RT
