OEM Wiring connectors
kerdoman
Post by kerdoman »
Thought it might be a good idea to use OEM connectors when installing farkles to keep the wiring looking tidy.
Anyone have a UK source for these, or are they just (probably expensive) Motorad stock items?
Re: OEM Wiring connectors
Be very carefull. Cutting into the Canbus can have some alarming results.
Levisp
Post by Levisp »
Safest way to add extras is with a fuseblock which is wired straight to the battery plus a trigger wire so power is supplied with ignition ON.
http://www.nippynormans.com/products/fu ... -exclusive
As far as I'm aware this is the only safe option with CANBUs / LINBus bikes. Have not done this myself so can not give any further advice but do a nerd search and I'm sure you will find a thread on the topic.
T6pilot
Post by T6pilot »
What are you adding?
I added P3 lights and Photon blasters followed Skene's directions and used supplied connectors. My escort 8500ci I piggybacked off the P3 lights power scource, no issues with canbus, knock on wood
kerdoman
Post by kerdoman »
The cunning plan is to take a 6way single pole fusebox directly from the battery and then feed Autocom, spot/fog lights, satnav, etc via isolation switches and warning lights.
Instead of using aftermarket connectors, an OEM look would be better.
