Does anyone now how to set the clock on a new R1200RT 2015 ? I can switch from GPS to manual, then what ?
Thanks setting-vehicle -time works
Set clock on r1200rt 2015 ?
Re: Set clock on r1200rt 2015 ?
I just put on the Nav V let it connect to the satellites and it sets the clock. You can also do it in Settings, Vehicle, Time
RTman10 wrote: I just put on the Nav V let it connect to the satellites and it sets the clock. You can also do it in Settings, Vehicle, Time
Ah - is that why it corrects itself when the clocks go forward/back??
:clap: :clap:
richardbd wrote: Ah - is that why it corrects itself when the clocks go forward/back??
:clap: :clap:
As you ride off the Eurotunnel it changed. dead smart.
What's that well known acronym.......RT*L ?? aka Read The F'ing Leaflet. Well, manual in this case!Bearbike1 wrote: Does anyone now how to set the clock on a new R1200RT 2015 ? I can switch from GPS to manual, then what ?
Your right first time. The small folded leaflet you get I find far more helpful than the book. Life's not that long.
We often refer to that one at work, RTFM Steve F wrote: What's that well known acronym.......RT*L ?? aka Read The F'ing Leaflet. Well, manual in this case!
- Spencert231
Commonly referred to in examination situation as RTFQ READ THE F#*$ing QUESTIONBenchmark wrote: We often refer to that one at work, RTFM
