Audio setting menu
Stebun
Audio setting menu
Post by Stebun »
When I switch on my ignition and use the mutlcontroller to access the audio settings all I get is Sirius and BT this is with bike stationary. When I rotate the MC for volume I only get "loudspeaker off" and tapping the on button only eclipses the volume off icon I cannot defeat the "loudspeaker off" message, :eek:
Steve Boone
Cleverbee
Re: Audio setting menu
Post by Cleverbee »
One presumes this is stock BMW audio system fitted by dealer?
Try using the buttons on the left side panel.  Also work your way through the Quick Guide card that clearly shows all the audio settings.
Stebun
Post by Stebun »
Thanks for reply, I discovered that I was not paying attention to the little arrow both above and below the selected setting. In my case my audio setting was defaulting to the Sirius setting and I was only scrolling down from there. Once I discovered the up arrow all was good. :thumbs:
Steve Boone
Cleverbee
Post by Cleverbee »
Remember, when all else fails, read the manual  :alas:
