Heated seat questions (2014+)
ckreling
Post by ckreling »
How fast does your main seat heat get not and is it very noticeable at setting 5(full).
Does the rear seat heat require someone to be in the seat (aka a pressure switch).
If you could check and let me know I'd be grateful so incas see if I have a warranty issue on my new to me '14th.
Thanks.
Re: Heated seat questions (2014+)
Easy answer on the rear seat.  No.  However it gets warm a lot quicker with someone sitting on it.  I have never needed to have mine set at anything more than 3 bars and then back to 1 or 2.  But everybody seems to be different presumably because of what you are wearing.
timminator
Post by timminator »
I have only used mine once or twice an it works wonderfully.  Dealer told me to start at max setting for a few minutes and then back down to 1 or 2, depending on the outside temp and your own comfort preference.
BMW MOA #210438
