COOLANT EXPANSION TANK HOSE ROUTING
I just wanted to pass some info to you all. My coolant level was low on the 2015 RT so I pulled the tupperware off to top it off. As I was snooping around, I noticed that the lower expansion tank hose was twisted causing a kink in the hose. I pulled the tank off, turned it 360 degrees and the hose returned to normal. So the next time you are in that area take a good look at that lower hose for correct routing. It must have been a Friday build.
- timminator
- Been liked: 2 times
Re: COOLANT EXPANSION TANK HOSE ROUTING
Great tip. I wonder if your bike has been running a few degrees hot since day 1.
BMW MOA #210438
