Wunderlich elephant tank bag
steve.sharkey
Post by steve.sharkey »
Anyone got/seen one of these:
http://www.nippynormans.com/luggage-tan ... your-model
Just looking for a little extra storage capacity for this years tours (Norway/Sweden & Switzerland/Austria)
Masq85
Re: Wunderlich elephant tank bag
Post by Masq85 »
Bought mine from someone on this forum.  Works just fine - easy to get on and off.  It does however sound the horn when on full left lock.  Other than that it's great.
chrisvh
Post by chrisvh »
Agree with above. Great tank bag. Easily transfered to different bikes with yoke. Very well made. Dies sound horn on full lock.
Hopefully gets nowhere near the kill switch on the right.
blokeonthemove
Post by blokeonthemove »
Unless you have upgraded your horn no one will hear it anyway!
steve.sharkey
Thanks, how does the "baseplate" attach? I believe the BMW bag requires some gluing which I'm not keen on.
chrisvh
Post by chrisvh »
The base plate has straps that go around the headstock and fastens using existing screws at the base. No glue and very secure.
guest2826
Post by guest2826 »
I have one for sale on the forum. Includes the baseplate for an RT LC.
/index.php?action=classifieds;sa=view;id=73
Littlebriar
Post by Littlebriar »
Have you considered the SW-MOTECH brand of bag? They feature a quick disconnect system that bolts to your fuel filler door frame. Works great. Pull the cord and off it comes. Easily snaps into position. Fits the RT very well. I have the Daypac model which is pretty large but not as large as the Wunderlich Elephant. No problems with the horn.
Steve
BeeJay
Post by BeeJay »
I use the Givi tank bag. Reason being it fits the same as the SWmotech, so that when the bag is off, all you see is the retaining ring on the fuel filler and a lot cheaper that the SWM.
Mind you I swapped my wife's SWM bag for the Givi one with my son, just bought the adapter ring.
All is good but with the bag expanded (upwards) it hides a lot of the instruments and on full lock it sounds the horn to advise you you're on full lock (lol).
All in all a good bag to carry all those bits you need after swmbo has filled the panniers and top box with her essential bits.
steve.sharkey
More options... by the time I order the Norway trip will be completed! I would miss the lack of map pocket though.
steve.sharkey
Just can't decide, I guess I'll be doing Norway without but I'll miss touring without a "map" pocket for my daily notes!
