indicator off switch not working
exman
Post by exman »
hi guys wondered if you can help how does the off switch for indicators work?indicators work ok but the switch does nothing
guest3074
Re: indicator off switch not working
Post by guest3074 »
exman wrote: hi guys wondered if you can help how does the off switch for indicators work?indicators work ok but the switch does nothing
What year bike?
Are you talking about the earlier bike that has a separate switch on each end of the bars for the appropriate indicator?
exman
Post by exman »
sorry 2011 rt mu with cruise esa asc
Don't want to spoil your day but that could be a complete left hand switch assembly replacement.
exman
Post by exman »
should it switch off when bike is stationary?
if you mean auto switch off, no.  That only happens above a certain speed.  But flick the switch either way to set them and then one press in with the switch in the central position should cancel them either moving or at a stand still.
Our Gee
Been liked: 29 times
Post by Our Gee »
Still not quite sure which RT model you have. Benchmark's question about the switch location is pertinent as a complete change of design took place with the introduction of the Twincam RT.
He says it's a 2011 so not the old 3 switch system.  That was last used in 2009 more's the pity.  It never went wrong.
exman
Post by exman »
yes 2011 everything works apart from off switch
Our Gee
Post by Our Gee »
RTman10 wrote: He says it's a 2011 so not the old 3 switch system.  That was last used in 2009 more's the pity.  It never went wrong.
Quoting a model by "year" only can be confusing. That's probably why Benchmark asked the question regarding switch type. For example, you could have a "2013" (date of 1st registration) bike that was built in 2011. If there where any changes incorporated between those dates confusion can arise. So it's always best to give as much info as possible, such as "it's a 2011 Twincam". Another example would be the two RT's registered in the same year with different Front Forks and so on and so forth. However, fully agree with your comments about the "old" twin paddle switch arrangement. I've had four bikes with then and never had a problem. Still that's progress (BMW style) I suppose.
