Tie down points when using a trailer
Can anyone tell me or send me pictures of the correct tie down points on the R1200RT
Re: Tie down points when using a trailer
I believe your owner manual has a diagram showing the tie down points, if you do not have a manual handy, several sites allow you to download it for free
- timminator
- Been liked: 2 times
I just hauled my RT halfway across the states using a U-Haul bike trailer. The tie down areas are on the forks in the front, just above the cross-brace, being careful not to pinch brake lines or other wiring. In the rear, connect to the frame just behind the foot pegs. One tip, always have the straps pulling the bike toward the front of the trailer. On the rear straps, use the center tie-downs on the trailer if available, not the ones in the rear. If the straps get into a tug-of-war the just end up fighting each other. Also, do not leave the bike on the center stand while towing, it puts too much stress on the bolts. Allow the bikes suspension to deal with all the bumps in the road.
And as T6Pilot points out, this is all in the rider manual, page 103 in mine.
BMW MOA #210438
I have found this style of short webbing loops really useful, they keep the hooks of rachet straps way from the bike and they are narrow so they can be feed easily, avoiding brake lines etc.
[size=13px]http://amzn.eu/2o95oWu[/size]
[size=13px]
[/size]
[attach=1]
[size=13px]
[/size]
[attach=1]
One morning I shot an elephant in my pajamas. How he got into my pajamas I'll never know. Groucho Marx
Thanks for that the only part I find confusing is no tension on bike suspension as mentioned.
- timminator
It works best if you have someone help you. Have them sit on the bike and balance it while you tighten the straps. Once they step off, the straps will naturally tighten up a bit. They need to be tight, but don't over-do it. Remember, the bike's suspension is holding the weight. The straps are really just balancing the bike, the same way your legs do at a stop light.Davcar wrote: Thanks for that the only part I find confusing is no tension on bike suspension as mentioned.
BMW MOA #210438
Every new bike comes crated to dealer, at least a half dozen straps secure the bike in the crate. My dealer was more than happy to give me a bunch of these straps at no cost, they have worked quite well when necessary to trailer one of my bikes
OP what makes this simple is using a wheel chock on your trailer, that is secured to the trailer deck. Once the front wheel is securely in the chock securing the front end is easy. The point of force of the tie down is on a fixed, non sprung area. Once the front end is secure you really only need minor force on the rear of the bike. With a wheel chock I use 3 tie downs, 2 in front 1 on the rear tire. 500 plus miles with two bikes on a 14 foot trailer, no issues, no movement.
Watching the delivery guys at the dealers loading the bikes they always put them on the side stand on full lock and pull down to it. The only difference I notice is if they use a unit with tyre tracks in which the front wheel locks in place and they pull down both sides. My challenge, getting the RT into a friends horsebox she needed collecting.
thanks and regards, Ganesh
