RT mirrors anchoring
- Has liked: 1 time
- Been liked: 9 times
Just a general alert with a simple fix. Lost both my mirrors in traffic (don't ask!). Turns out they are only attached by three ball joint posts seated loosely in rubber receivers. Per a suggestion on this site, I've simply looped a zip-tie through the mirror and base plate. They can still pop out, but the tie will stop it after an inch or so. Just be sure to leave enough of a "tail" on the tie near the outer edge to allow you to grasp it to make it easier to cut the tie to afford you access when removing the body panels, etc. underneath the mirror.
Re: RT mirrors anchoring
On my '08 RT, their is a metal wire connecting the mirror to the fairing, so there is no way to "lose" the mirror if it is knocked loose. I assume that was standard? (I bought my bike used, so could have been added after the fact by the previous owner). How do I know about this? Like you said .... don't ask.
- Has liked: 1 time
mcwhirtj wrote: On my '08 RT, their is a metal wire connecting the mirror to the fairing, so there is no way to "lose" the mirror if it is knocked loose. I assume that was standard? (I bought my bike used, so could have been added after the fact by the previous owner). How do I know about this? Like you said .... don't ask.
I think it's optional. I've seen them for about $6 in official BMW parts catalogues. But the wire seemed so long that I feared the dangling mirror would flap around in the breeze if it came off at speed, maybe scratching the body panels.
I have a 2008 and no metal wire. Must be a preventive measurement added by the prev. owner. Since you have them and are long, am sure you can loop them such way to make them shorter. One will never know how valuable is to have them anchored until loses a mirror!mcwhirtj wrote: On my '08 RT, their is a metal wire connecting the mirror to the fairing, so there is no way to "lose" the mirror if it is knocked loose. I assume that was standard? (I bought my bike used, so could have been added after the fact by the previous owner). How do I know about this? Like you said .... don't ask.
Zip ties are cheap, mirrors are not!
