Have had my Nav VI for about 1 year.
I seem to be confused on how to continue my route from where I had lunch and the nav VI was shut off during that time.
Any help to clear up my confusion is greatly appreciated.
Nav VI, How do I continue a route after lunch?
- Rambler358
- Been liked: 1 time
Re: Nav VI, How do I continue a route after lunch?
The route should automatically continue once you start moving again.
As mentioned it should pick up where it left off. Garmin GPS, for motorcycles anyway, that I have had go through the following process.
Bike shuts off, screen responds do you want to shut down, yes or no with a statement giving you so many seconds to respond before it shuts down by default.
When starting the bike up, it can take a minute or more for the GPS to respond after it has acquired the satellites it needs to fix it's position. The route with your location then continues on.
I have yet to see if the new VI is something different in function.
Just tried it out here at work. GPS is not attached to the bike. Added a route home. Turned the GPS off. Then turned it back on. The display did not show the map image I had to press the View Map icon and there my route was.
Ed
Ed
Thanks Ed, I really appreciate your input.
Ride safe
Bob
Ride safe
Bob
Better to burn out than fade away. - Niel Young
- Has liked: 81 times
- Been liked: 147 times
etitanic wrote: Turned the GPS off. Then turned it back on. The display did not show the map image I had to press the View Map icon and there my route was.
Ed
That's the one, Just press the "View Map" icon on the screen and all is resumed.
- Rambler358
You don't even have to press View Map. Once you start moving the GPS will automatically switch over to Map View.
Rambler358 wrote: You don't even have to press View Map. Once you start moving the GPS will automatically switch over to Map View.
I paid for that button... I'm using it!!
- Sprintgull
+1!!!!
