Getting On The Bike
Getting On The Bike
Hi
Is it safe to stand on the side stand when getting on the RT?
I have a drivers back rest which makes it difficult when getting on the bike?
All reply’s welcome.
David
David
Re: Getting On The Bike
I step on the right peg and swing my left leg over onto the bike. I can not see how you would affect the side stand this way. The second you stand on the right peg you remove weight from the side stand not add weight so can see no way it is harmful to the side stand.
That makes sense although it Is probably important that the bike is on level ground and not leaning to the left on a bit of a slight slope.
Regards
David
Regards
David
- Has liked: 61 times
- Been liked: 134 times
I seen plenty of people do it. The only thing I would be wary of was if the side stand was on a slightly softer surface or even tarmac in very hot weather. Even for a short time it seems that you are putting a considerable amount of extra weight through it (no offence intended) until you get the bike upright.
I guess you need to go through it once to see how it works. Once you step on the right peg you un weight the side stand. Once your left foot hits the ground the bike is all but stood up and LESS weight is on the side stand.
Like I say once you do the motion and watch the bike's suspension you will see.
IMHO getting on the side stand side and sitting down on the side stand puts more stress on the bike then standing on the right peg and relieving the weight on the side stand and standing the bike up off the side stand in that same step on motion.
As to what the stand is sitting on again it lifts the side stand when you step on the right side, so even if it has settled you are using your weight as leverage to bring it out of what it has settled in.
Sorry, Ive got a bit lost on which side of the bike you're getting on.
I assumed that you were " mounting" from the left, which is the technique I've seen most when using the side stand down.
As in:
As in:
I always put my weight ,(14 stone) on the left peg when swinging aboard the RT, no probs with side stand, it's pretty meaty and strong.
PS. can't ride or do anything now for 3 months and continuing since I snapped the Achilles tendon in my right ankle putting my Honda Crosstourer on it's centre stand.
Mondeoman
My wife has mobility problems so she normally gets on the bike first whilst it is on the side stand, then moves to the back seat, then I get on a stand the bike up. Done this with multiple bikes and never been a problem.
Mondeomanmondeoman wrote: I always put my weight ,(14 stone) on the left peg when swinging aboard the RT, no probs with side stand, it's pretty meaty and strong.
I did the same thing 3 years ago putting a Honda scooter on stand, follow your doctors and therapist’s advice 110%, recovery sucks, much worse than knee replacement
- Has liked: 1 time
- Been liked: 9 times
I don't use the pegs myself, but it would appear easier and safer to use the right hand peg. The left one will be tilting downward, making it easier to slip off, especially in wet conditions. On the right, if you slip the tilt will slide your foot safely up against the side of the bike. I have always instructed my passengers to mount as if getting on a horse: right foot on the rear peg, stand straight up slowly, and easily swing the left leg over, with plenty of rooms to spare. I found that passengers naturally tend to sort of karate kick their way onto the bike, often overbalancing. If the passenger is heavy, I'd recommend you perform the above maneuver with the side stand down for safety. As to the strength of the pegs, I have to say I had a very slow static fall (the type where you realize you can only slow the inevitable crunch) and the rear peg - extended at the time - snapped right off. In cross-section it looks just like aluminum pot metal, similar to the upper swing arms of the windshield which have twice snapped. Plus can't be mended even with the proper welding technique. Kind of disgraceful they try to save on costs given the ridiculous part prices. BTW, in a pinch, the rear peg also fits the front. I have popped the return/tensioner springs on the front so I can fold them up, since I hate barking my shins whilst backing up, and you can put you leg straight down to help flat foot it. Works a treat.
T6pilot wrote: Mondeoman
T6, wow, you too 'eh, I'm hopefully into rehab in 3 weeks all being well so fingers crossed !, really miss riding the bikes.
Mondeoman
I step on the right side, throttle side peg. Swing my left leg over to the ground and the bike is stood upright.MikeS wrote: Sorry, Ive got a bit lost on which side of the bike you're getting on.
As in:
The bike is not tipping over unless you have it balanced strait up and down. Most of our police use this technique to stay out of a traffic lane when getting on or off the bike.
You are 200 lbs stepping on a bike that is 550 lbs that is still resting on the ground. When you step on the right side you unweight it, pull the side stand out of the asphalt or mud, and upright the bike all using gravity not muscle.
- Sprintgull
The only thing that would be a concern to me when mounting from the right side would be that the LC seems to have a long side stand and does not actually lean far to the left. If it were on a slight slope it would be almost upright, and I'm umm heavy. Could it topple? I hope no-one come back and says 'yes' from experience.
All this talk of getting aboard the bike while it's on the sidestand, from the right hand side is giving me a headache thinking about it! To me, I can't see the advantage, if there even is one. The right side is the high side. If my bike's on the sidestand, leaning over to the left, then that, surely, is the side to get on....the left. As you get on, you naturally push the weight off the sidestand so you and the bike are then upright....and both feet are on the ground should a pillion be about to climb on.
This assumes, of course, that we're all using 'right' to mean the right when sitting on the bike!
Pete
Pete
- Has liked: 72 times
- Been liked: 71 times
I stand on the left peg when it's on the side stand to get on. It's easier not to kick the panniers that way.
I'm probably heavier than all of you, and I've not broken the side stand yet!
