Alarm
Alarm
DWA........ DiebstahlWarnAnlage = Theft Warning Device.
Got this fault but no fault code. I think it may be the alarm batteries but thought they should last longer than the 2.5 years of the bike. Any one change theirs and how long did they last.
But
Not got the DWA battery low warning on the dash.
Or
It could be that the alarm has been triggered?
XDWA : -[/size]Controller Type : Anti-Theft AlarmController Name : XDWAController : 0F8700Manufacturer : META System S.P.A.Manufacture Date (YY/MM/DD) : 17/05/08VIN : Z263457Program Count : 0Program Count Maximum : 1024Firmware Date (YY/MM/DD) : 17/05/08Kilometers when programmed : 0.00 Number of FW configurations : 4..HW Electronics (HWEL) : ....Firmware ID : 0A4C....Firmware Version : 001.000.000..Bootloader (BTLD) : ....Firmware ID : 0A49....Firmware Version : 001.000.000..SW Memory Image (SWFL) : ....Firmware ID : 0A4A....Firmware Version : 001.006.003..Coding Data (CAFD) : ....Firmware ID : 0A4B....Firmware Version : 002.000.000Fault Codes : 1
Re: Alarm
Put new Duracell in that measured 3.2v and no fault count. Must have been something to do with higher voltage of original batteries......... or something?
XDWA :
Controller Type :
17/05/08VIN : Program Count : 0Program Count Maximum :
....Firmware ID :
....Firmware ID :
....Firmware ID :
....Firmware ID :
0A4B....Firmware Version :002.000.000
Fault Codes :0
No Faults found :
XDWA :
Controller Type :
....Firmware ID :
....Firmware ID :
....Firmware ID :
....Firmware ID :
Fault Codes :0
No Faults found :
