***SOLD***2013 RT SE, under 10k miles.
milleplod
Post by milleplod »
It's with a heavy heart that I'm advertising this lovely bike, but, after my collision earlier this year with an HGV, I've decided to hang up my boots.
First registered to BMW, this bike was bought straight from the showroom by the chap I got it from back in July. It's done under 10k miles - no corrosion, all the extras bar the radio setup, and everything works just as it should. The dealer fitted the heated, one-piece 'comfort' seat, which really is a revelation compared to the standard one. It's not the low version btw.
The bike was serviced by BMW up until 5550 miles in March of 2015.
MoT history shows the mileage as follows -
Sept. 2016 - 8401 mls
Feb. 2018 -  8580 mls
Apr. 2019  -  8789 mls
Mar. 2020  -  8939 mls.
The bike was home-serviced over this period - there are no receipts unfortunately, but when I serviced it at 9312 mls in last month, the air filter looked brand new, as did the final drive and gearbox oils, so I've no doubt whatsoever that servicing was done. I also dropped the rear drive to check and grease the splines - it was like new in there, probably better as there was plenty of grease and not a trace of corrosion or moisture. I also fitted stainless brake pad pins front and rear.
There's a satnav mount above the instruments, currently fitted with a Tom Tom powered holder. I have a Rider 40 to go with the bike if I get the price I want.
The panniers were fitted with flexible, clear protection from new. Some scuffs are visible on the protectors, but the paint underneath will be like new. I have the genuine inner pannier bags, plus a good-quality aftermarket one for the topbox. All 3 boxes use the ignition key. There's an Autocom unit under the seat - I've never used it, and it will need someone who knows what they're doing to recommission it I think, as when I bought the bike it was connected in to a Garmin 660 that had been fitted by the dealer - I removed that in favour of the Rider 40, meaning there are now a few redundant connections taped up around the headstock.
I fitted genuine head protectors when I bought the bike, not shown in the photos. Tyres are almost new PR4s.
This is a genuinely lovely bike, it really is. There might be the odd, tiny little mark to be found (it's done almost 10k miles, after all),but nothing that catches the eye.
I'm in Derbyshire, near to junctions 29/30 of the M1.
£7650 ovno.
Pete
[attach=1][attach=2][attach=3][attach=4][attach=5]
Re: 2013 RT SE, under 10k miles.
Hi Pete, sorry to hear that you have decided to sell your recently acquired RT.
Hopefully, you'll continue to use and contribute to the forum as you have a wealth of knowledge & experience with RT's etc.
Cheers, David.
milleplod
Post by milleplod »
Now sold.
