Sirius radio installation
Dartman340ta
Post by Dartman340ta »
First off.  My 2015 came with no options (none ) so I like that.  But I like Sirius radio.  So here goes SiriusXM receiver ,no radio, and a Sena 20 headset . So i also have this tiny little thing taotronics wireless 2 into 1 it inverts the signal or what ever it does to the headset from the Sirius receiver.
      So. My question is do y’all think this will work.  I’m far from being any kind of this kinda stuff a guru
Dartman340ta
Re: Sirius radio installation
Well I’ve been installing all this stuff.  Easy  Hard part is pairing the radio in Sena with SiriusXM receiver. The Sena has no metering numbers on it so you don’t know where your dialing the radio station to. Then you make that your pre set radio station.
Dartman340ta
Well y’all I got it all figured out. I needed a tactronices transmitter/ receiver.  Put on transmit plug it to the Sirius then pair Sena per the second phone Bluetooth make sure they pair took me a couple try’s but once hooked up paired music to my ears.
