Pannier protection from BMW
Has liked: 425 times
Been liked: 349 times
Hi
In a rash moment I ordered the rubber/plastic and hideously expensive pannier protection guards.
£155 later I have 4 bits of plastic with some thin allegedly sticky bits to press in non-indicated positions against the pannier… no cleaning wipes, no instructions.
I appreciate it’s probably meant to be self evident but with these things you get one chance, try and remove to replace them elsewhere and the damn things will undoubtedly fall off.
Impressed? No… just a warning really, don’t bother.
T6pilot
Re: Pannier protection from BMW
Post by T6pilot »
I’ve used the BMW skid protection on both my 1600gt and 1200rt, I can honestly say they work, I’ve had in my weaker moments a couple zero speed tipovers with only a little scratching on the protectors and obviously protected the paint
Takes a little planning on their install before you pull the tape off, some swabs dipped in alcohol to clean the surface and your good to go
One tip, remove and lay panniers on their side
60Aviator
Bike Model and Year: 2017 GSA & 2021 R1250RT
Has liked: 8 times
Been liked: 14 times
Post by 60Aviator »
They should have come with a template as mine did. Here are the instructions maybe dealer can print a new template.
case protection.pdf
(716 KiB) Downloaded 268 times
60Aviator wrote: They should have come with a template as mine did. Here are the instructions maybe dealer can print a new template.
Invaluable, thanks for the replies. 👍
