Just bought a used 2019 R1250 RT with the Akropovic exhaust. I’m not a fan. Too loud for me. I’d be glad to trade, for not cost, my upgraded slip on for the stock can.
Thanks not question I have is, will the stock muffler fit on what I believe is the Akropovic header.
Akropovic exhaust - FREE
- 60Aviator
- Bike Model and Year: 2017 GSA & 2021 R1250RT
- Has liked: 8 times
- Been liked: 14 times
Re: Akropovic exhaust - FREE
I have a stock can I will trade. I don't know if stock can will fit on that header though.
Okay, let’s see if any of the experts can help us figure out the fitment issue.
I’ll take some pics to establish condition (if I can figure out how to load them here).
- Been liked: 387 times
If the header is an Akrapovic, does it include an integrated catalytic converter.TeeJayAZ wrote:I believe is the Akrapovic header.
If not, this could contribute to the noise level even with a stock can fitted.
As the Akrapovic slip-on is designed to fit the stock headers, I'd be very surprised if the stock can doesn't fit an Akrapovic header.60Aviator wrote:I have a stock can I will trade. I don't know if stock can will fit on that header though.
This is what the stock header and can look like.
Akrapovic slip-on, showing inlet pipe and clamp.
You may find fitting a standard end can will have no impact on the issues you are experiencing. I have an Akrapovic end can on my 2019 1250 and haven't experienced the issues you describe, but I have the standard headers. If you have Akrapovic headers, I have read elsewhere that the bike should have been mapped as the standard mapping is not ideal when you change the headers for aftermarket ones. But maybe a call to Akrapovic would confirm. To the other question, the Akra can and standard can use exactly the same mountings therefore the standard can would fit the Akra headers. But the standard can has a different heat cover, which you take off if you fit the Akra end can, as that has a kind of carbon effect cover.
If the bike is indeed found to be fitted with an Akrapovic header, is it with or without a catalytic converter.
- Bike Model and Year: 2020 r1250rt
- Has liked: 2 times
Hello
If it does not work out with the other member that replied, I would be interested in trading my stock can for your Akaropovic. By you member name you might be in Arizona, if so I could ride to you to do the exchange.
