Just replaced my rear brake pads with EBC HH pad. I know BMW recommends standard sintered pads on the rear but i like the feedback from the HH pads.
One question i have is why is one pad thicker than the other?. I've contacted EBC and they inform me i have the correct pads but the person couldn't explain why one is thinner than the other. Do you know why?
rear brake pads 1200 2007
- Has liked: 1152 times
- Been liked: 306 times
Re: rear brake pads 1200 2007
I've no idea why, but if that is the case surely they have to be handed. Seems strange to me :-XDoctor T wrote: One question i have is why is one pad thicker than the other?. I've contacted EBC and they inform me i have the correct pads but the person couldn't explain why one is thinner than the other. Do you know why?
- Been liked: 395 times
From what I have read elsewhere https://www.ninetowners.com/threads/uneven-rear-brake-pad-thickness.141033/Doctor T wrote:One question I have is why is one pad thicker than the other.
and having viewed this video, Disk brake / Floating caliper brake - How it works! (Animation) - Bing video
the outer pad (nearest the piston) is thicker than the inner because the rear brake has a floating caliper.
In the video, as the brake is applied/released, the outer (thicker) pad makes & remains in contact with the disc fractionally earlier & longer than the inner pad.
Seems like a reasonable theory.
They are, BMW R1200RT Rear Brake Pad Service - YouTubeyorkie wrote:If that is the case surely they have to be handed.
Thank you David, live and learn eh ^-^David. wrote: They are, BMW R1200RT Rear Brake Pad Service - YouTube
It's strange ive never seen this on other bikes ive owned over the years. Are there any other makes of bikes that have the same set up?
Triumph, '98 Sprint Sport - two rear brake pads are different thickness | Triumph Rat Motorcycle ForumsDoctor T wrote:Are there any other makes of bikes that have the same set up?
