Checking the oil level this morning and ive noticed a dirty layer of oil coming from the front cover. I guess it is from the front crankshaft seal.
Can someone help me with the part numbers needed? The bike is an August 2007 model.
I. Front crank seal. Think this maybe 11 11 8 528 387
2. Alternator belt ( as the front cover is coming off, may as well change at the same time)
Not having a good W/E Part numbers help
- Has liked: 1148 times
- Been liked: 306 times
- Been liked: 393 times
Re: Not having a good W/E Part numbers help
From MAX BMW, 11 11 8 528 387, SHAFT SEAL - 36 X 50 X 7.
Cheers David was hoping you would come up with the numbers.
