Hello all
I’ve recently purchased a 1250RT LE and I’m thinking of fitting sat nav but I’ve heard such horror stories about the nav6. So now looking at the Garmin Zumo XT but obviously need the conversion mount which I’ve read up on and it seems the 3DAM seems the best at present. I know that the nav6 could be locked in place by modifying the base plate and tapping into the central locking but my main question is “can you lock the unit in with the central locking or does it just lock the mounting plate”? I’m assuming you can’t fix the Garmin to the mounting plate.
I hope this all makes sense. The nav6 seems to have some advantages re. security but that’s no good if it fails to work.
Any thoughts, advice or information would be appreciated.
First sat nav on 2020 RT
- Has liked: 1075 times
- Been liked: 281 times
Re: First sat nav on 2020 RT
Hi can you introduce yourself before posting anymore in the Newbie section? We are a nosey lot
- Stu
- Administrator
- Has liked: 539 times
- Been liked: 487 times
Hi and welcome to the forum
The central locking add on simply stops the release button from being pressed
With the 3DAM mount it would still work but there is a gap between the zumo and the fairing surround which would allow fingers to get in and the zumo to be ripped off
Probably causing untold damage! I just remove the XT to stop this happening
- Bike Model and Year: R1250RT LE
- Been liked: 3 times
Thanks for the reply.
Reading through the available detritus on the internet it would appear that the issues around the nav6 have been resolved and Garmin have rectified the issues of the screen jumping and freezing. I am leaning towards the nav6 with a locking plate wired into the central locking for security although I’ll probably still remove it if parked up. I can’t understand why BMW didn’t incorporate the sat nav lock into the central locking in the first place but the box with a duster in is locked. I’m not planning to tour Europe but planning some decent routes for rides out would be good. Thanks again.
Garmin have tried a couple of times to solve the issues with the Nav VI. The latest fix (updated Nav VI) up to yesterday hasn't yet been shipped. We have a Nav VI that is less than 6 months old that is ghosting and Garmin gave an estimate of 8 weeks to replace. So not sure if you can buy the latest fixed Nav VI yet.
I lost patience and fitted a Zumo XT to my 1250. Didn't bother with the 3d printed gizmo, I just bought 4 longer bolts and 4 spacers and mounted the XT holder in front of the Nav mount, and powered it with a lead that just plugs in where the Nav VI gets its power from. Security wise, the release for the XT is on the top of the device, which you can't actually press whilst it is mounted in the cowl, so you need something like a trim removal plastic tool to insert to release the Nav. Not secure enough to leave the Nav in the holder overnight, but stops the casual walk by thief. But no locking device is going to stop the determined thief, they will just be able to prise the Nav off, so I remove the XT for longer stops.
- Has liked: 14 times
- Been liked: 79 times
I've been using and XT & 3DAM combo on my 1250RT for over a year now. It looks OEM and just works. In terms of security, I don't bother, if some scrote wants the nav they'll just rip it off and I'll be left to deal with the damage as I doubt the insurance company pay out as it's an after market accessory. I just take it off (complete with the adaptor) and put in my top box or pannier.
The XT has a few 'by default' annoying features that need turning off (mostly bleep & pings) and loads of stuff I just don't use, but overall it's a good unit and I'm happy enough with it.
- jclaudej
- Bike Model and Year: 1250 RT 2019
- Has liked: 11 times
- Been liked: 14 times
- Contact:
Hi,
An other solution is your smartphone with GPSapplication as (for example) Cruiser and Wunderlinq.
After you will be free to choice the bes GPS application for you and with Cruiser no limitation of waypoint.
Look at here viewtopic.php?t=6721
