So i fitted error free LED bulbs to the low and high beam.
When i tested them on the bike without the engine running everything was ok.
Today i was able to start the bike for the first time since fitting them.
The low and high beams are still working as they should, but its now giving me and open circuit error for both.
Any thoughts please.
HeadLight LED Fault
- EasyRider
- Has liked: 113 times
- Been liked: 281 times
Re: HeadLight LED Fault
So from what i've just been reading, even though there error free LED bulbs the resistance could still be off enought to flag up the canbus warning light on the clocks.
- EasyRider
All sorted for the moment. I've put the normal bulbs back in untill i am in the mood to sort it out.
- Steve398
- Has liked: 387 times
- Been liked: 315 times
The Cyclops LED bulb set seem to be the most popular as they work with no reported errors, but they are pricey.
- jclaudej
- Bike Model and Year: 1250 RT 2019
- Has liked: 11 times
- Been liked: 14 times
- Contact:
HI from France,
I use this product without CanBus error => https://fr.aliexpress.com/item/10050049 ... pt=glo2fra
- LDA
- Bike Model and Year: R1200RT 2012
- Has liked: 1 time
Are you still pleased with these Auxito H7 led bulbs? No errors? Still working fine?
