Turn off aux light warning with GS911??
Lynxfixer
Post by Lynxfixer »
So, one of my aux lights went tits up so I've removed them. Too expensive to replace. However, when i remove the aux light switch I get a warning on the dash. I know the aux lights are programmed into the canbus sytem, can I use the GS911 to stop this warning appearing.
Cheers.
Has liked: 559 times
Been liked: 519 times
Re: Turn off aux light warning with GS911??
Unfortunately not no!
It's a trip to the dealers to get it coded out
I had the same issue but instead I replaced the lights under protest for the newer nano ones
