R1200RT 2008 fuel leak
rzsdnc
Bike Model and Year: R1200RT-2008
Turkey
Post by rzsdnc »
Hello everyone,
I own a 2008 BMW R1200RT.
There was a fuel leak from the fuel pump connector.
When I opened it, I found that the gasket was old and worn out, so I replaced it, and the leak stopped. However, the leak reappeared after 2 days.
It seems that the previous owner had probably dealt with a leak at the bottom part, and a transparent, hard adhesive, likely an "epoxy" type, was applied there, which is quite hard.
Now, I have ordered a new set. But if I try to open it without removing the hard adhesive at the bottom, it might break.
I don't have tools like a Dremel.
How can I remove this adhesive using more primitive methods?
Istanbul/Turkey
https://www.youtube.com/shorts/mDNa8se9Ebo ( before )
https://ibb.co/1T8Y2kL (connector)
https://ibb.co/DWxRVYz (o-ring)
https://www.youtube.com/shorts/0UTWYQOWqA8 (after)
Has liked: 45 times
Been liked: 42 times
Re: R1200RT 2008 fuel lake
You can always sand off the epoxy, but it is very labor-intensive.
rzsdnc
Turkey
Post by rzsdnc »
Randyjaco wrote: Mon Jul 01, 2024 10:40 pm You can always sand off the epoxy, but it is very labor-intensive.
As you can see, it has been applied here in a haphazard manner.
I am thinking of breaking it up by slowly tapping on it with a nail or a hammer.
Been liked: 379 times
Probably best to leave the adhesive alone. On some Hexheads, there was a problem with the plastic flange cracking and leaking, a reinforcing metal ring was fitted. The adhesive may have been used to secure the ring.
"If it ain't broken, don't fix it", leave well alone.
Has liked: 113 times
Been liked: 281 times
I'm with David on this, leave it alone.
rzsdnc
Turkey
Post by rzsdnc »
David. wrote: Tue Jul 02, 2024 6:09 am Probably best to leave the adhesive alone. On some Hexheads, there was a problem with the plastic flange cracking and leaking, a reinforcing metal ring was fitted. The adhesive may have been used to secure the ring.
There is still a gasoline leak coming from under the adhesive you see there.
Re: R1200RT 2008 fuel leak
In this photo, cracks can be seen at the connector flange.
It is possible that adhesive has been used to repair a leak which has now reappeared.
