Hi All
I have a 57 plate 07/08 1200rt
I had an oil leak at the final drive and when you ran the bike looked like a buckled wheel so it's the internal bearings have gone so I purchased a secondhand drive from Germany and it eventually arrived it was in extremely good condition so I fitted and put 180ml of oil in but when I went to plug in abs sensor it does not fit the the new unit it is too big so I'm wondering if it's a case of purchasing a different sensor the vendor said it came off an 06 and although the part numbers are different what I had read was that August 06 the partnumber changed to what the original drive was so thinking it was just a part number change so any advice welcome
Final drive
Re: Final drive
According to bmw it may throw up an error on the dash because the abs rings may not be the same and the only way to check the abs rings is to open the 2 units and I don't have a 5 legged puller
Thankyou
Thankyou
- Been liked: 395 times
Re: Final drive
Having looked at MAX BMW parts catalogue, from 08/06, the final drive unit changed from ABS GEN. 1 to ABS GEN. 2.
Have a look at this thread viewtopic.php?p=12758&hilit=final+drive#p12758, it might be worth contacting Mike Overy or Steve Grover for advice.
