Bike turner
lancashirert
Has liked: 39 times
Been liked: 20 times
Bike turner
Post by lancashirert »
Moving house soon, and will have a garage down the side of the house which is an incline and also only the width of the garage.
Any suggestions and recommendations for turners? Seen you can get centre stand ones, and also the type which you ride the bike on to and then you can wheel it round the garage. Not aware of any other ideas offhand, although the daughter’s flyweight Vespa suddenly looks more appealing to put away than a 1/4 ton bike :lol:
Cheers!
Bike Model and Year: NUFFINK
Been liked: 321 times
Re: Bike turner
I have the centre stand jobby,OK in the garage,wouldn't chance it on an incline for fear of rolling off.I had one of the long ones you pop the bike on then on to its side stand,maneuverability is nowhere near as good as the centre stand one(in my opinion)and again,maybe an issue on an incline.
A possible alternative is the rear wheel lift(like they use in paddocks)grips the tyre/wheel and allows you to spin the bike round on the spot,maybe the best solution but probably the most expensive.
lancashirert
Has liked: 39 times
Re: Bike turner
I definitely have no intention of turning it on the incline! Just to turn it in the garage really.
Could look at rear wheel lifting. Have a wheeled paddock stand still…. Shall have a look at a centre stand turner though, thanks.
Arends
Has liked: 39 times
Been liked: 6 times
Ireland
Re: Bike turner
Post by Arends »
I've seen on YT a lazy Suzan mechanism/bearings mounted on two sheets of plywood, but the user had lighter bike.
I am here to learn.
Has liked: 43 times
Been liked: 144 times
Re: Bike turner
I use a 50cm version of this
lancashirert
Has liked: 39 times
Re: Bike turner
Glenn wrote: Mon Oct 07, 2024 7:20 am I use a 50cm version of this
That's neat, will search as out of stock on his link.
Found this type last night: https://www.amazon.co.uk/gp/product/B0D ... ct_title_2 - which might allow a little shunting too.
Re: Bike turner
That's similar to what I use
That was a mighty bike :lol:
Takes the weight of the RT no problem.If you go down that route,make sure the floor is fairly smooth :thumb:
lancashirert
Has liked: 39 times
Re: Bike turner
burridge01 wrote: Mon Oct 07, 2024 1:52 pm That's similar to what I use
This is the conundrum, I can’t remember the garage floor! And I need it the day I move, or rather the next day I want the bike out!
Has liked: 1136 times
Been liked: 304 times
Re: Bike turner
I have the same as above. I have an uneven bumpy floor in my garage and it works well. Think I paid about £35 delivered from Ebay.
Re: Bike turner
Doctor T wrote: Tue Oct 08, 2024 12:50 pm I have the same as above. I have an uneven bumpy floor in my garage and it works well. Think I paid about £35 delivered from Ebay.
Mine did move but it was to erratic, so I got some filler gear of a job I was on and after filling said holes it was all a lot smother :thumb:
