Gear Shift Assist Pro
Re: Gear Shift Assist Pro
If you have warranty take it back. Did it just suddenly stop working or slowly pack up.
Out of warranty, It was fine when i last used it first run after the winter wouldn't work?
Can only suggest you visit your dealer to get the control unit checked.
If anyone has a GS-911 around you they can reset the transmission, then you need to re learn it by running it in each gear for 10 seconds. Just saying maybe just needs reset for some reason. You MUST do the re learn though.LC cool wrote: Out of warranty, It was fine when i last used it first run after the winter wouldn't work?
Please let us know.
