screen problems
delboy1145
screen problems
Post by delboy1145 »
I have just taken delivery of a r1200rt 2011 a couple of weeks ago and I'm certain that when I turned off the bike the screen automatically returned to the parked position but now it doesn't. is this normal or am I dreaming.
The bike is a R1200 RT SE 2011
Has liked: 101 times
Been liked: 232 times
Re: screen problems
My 2011 stays where it is when I turn it off, It only moves when I press the raise/lower button.
Re: screen problems
The screen only parks itself on the LC.
delboy1145
Re: screen problems
Thanks for that I hired one in Florida and rode to Key west and that parked when switched off and I fell in love with the RT and bought one when returned home and could not remember if the screen parked on the SE or not but as its on a three month warranty I thought I had better check
Dave
Re: screen problems
The system first appeared on the K1600 in 2011, the idea being that when it's down you couldn't get at the Navigator.  One day, some day BMW might just fit the same system on the RT.
k9doc
Has liked: 7 times
Been liked: 17 times
Re: screen problems
Post by k9doc »
Worked the opposite way round on the FJR. Early ones self parked, then someone devised a work around removing some bit or other, and the later ones didn't self park. Seems to me that if you have your screen set up nicely for the prevailing conditions, why would you want to have to reset it after a comfort stop. It is hardly a major consideration at the end of the day to park the screen if you so desire, but I suppose the same applies resetting it during a ride. The FJR didn't have the complication of a GPS high on the dash to fiddle with.
Chris
Re: screen problems
k9doc wrote: Worked the opposite way round on the FJR. Early ones self parked, then someone devised a work around removing some bit or other, and the later ones didn't self park. Seems to me that if you have your screen set up nicely for the prevailing conditions, why would you want to have to reset it after a comfort stop. It is hardly a major consideration at the end of the day to park the screen if you so desire, but I suppose the same applies resetting it during a ride. The FJR didn't have the complication of a GPS high on the dash to fiddle with.
But the LC does return to its setting when you start agsin.
Re: screen problems
Another BMW built in wallet lightening feature causing extra wear on the motor leading to expensive premature replacement perhaps?  ;)
k9doc
Has liked: 7 times
Re: screen problems
Post by k9doc »
RTman10 wrote: But the LC does return to its setting when you start agsin.
Best of both worlds then, technology marches on. Problem is keeping up with it, especially for us old pharts (speaking personally).
Chris
Paggers
Re: screen problems
Post by Paggers »
My only objection with the LC screen (and I know this has been covered extensively elsewhere) is when you want to wash it. There is no choice but to turn the bike on while cleaning so you can have the screen up - which is really annoying.
gogs01
Re: screen problems
Post by gogs01 »
Paggers wrote: My only objection with the LC screen (and I know this has been covered extensively elsewhere) is when you want to wash it. There is no choice but to turn the bike on while cleaning so you can have the screen up - which is really annoying.
Or remove it and do the job properly ? :D
Been liked: 46 times
Re: screen problems
gogs01 wrote: Or remove it and do the job properly ? :D
Continually removing the screen is apparently not a good idea, there is a possibility of messing up the screws the hold the screen on, this is something I read on another forum, so not from my own experience. For the couple of minutes it takes to wash the screen, having the ignition on, doesn't cause me any issues, but i guess its like the sat nav lock discussion, different things annoy different people  8)
gogs01
Re: screen problems
Post by gogs01 »
Casbar wrote: Continually removing the screen is apparently not a good idea, there is a possibility of messing up the screws the hold the screen on, this is something I read on another forum, so not from my own experience. For the couple of minutes it takes to wash the screen, having the ignition on, doesn't cause me any issues, but i guess its like the sat nav lock discussion, different things annoy different people 8)
I don't see why regularly removing the screen should be a problem (which doesn't mean it won't be !), but I only go that far a few times a year to get it properly clean, as with the silencer etc.  For normal washing I'll switch the bike on but have the kill switch off, because I seem to remember that having direct current passing through a coil can cause it to overheat and fail - or did that end with electronic ignition ??
Re: screen problems
gogs01 wrote: I don't see why regularly removing the screen should be a problem (which doesn't mean it won't be !),but I only go that far a few times a year to get it properly clean, as with the silencer etc.  For normal washing I'll switch the bike on but have the kill switch off, because I seem to remember that having direct current passing through a coil can cause it to overheat and fail - or did that end with electronic ignition ??
I remember the killing the coil thing, but thought that issue went away years ago, but never researched it, so not sure.
ibroxblue
Re: screen problems
Post by ibroxblue »
R1200RT LC 2017 had the same issue after pressing and holding my turn cancel button. Tried putting the screen up and holding the button. Worked a treat thanks.
