Here you go Doc.
https://www.aliexpress.com/item/1005004 ... ry_from%3A
GS Top Yoke Conversion Kit
- EasyRider
- Has liked: 152 times
- Been liked: 368 times
Re: GS Top Yoke Conversion Kit
I also removed the cable tie this morning and there were NO leaks from any of the joints.
Don't forget to use new copper crush washers.
- Bike Model and Year: R1250 RT LE 2019
- Has liked: 15 times
- Been liked: 14 times
Looking very good and post saved for my decisions on riding position once I can get out more with the wife. Just a thought at 4 years or so, we have the same year bike, the brake master cylinder cap rubber will have lost the ability to seal properly. I bled my brakes last autumn and thought it was all dry until I took the bike off the centre stand and a drop of brake fluid landed on the fairing. It seems the brake fluid finds its way out and almost invisibly runs between the master reservoir and underneath via that little channel next to the bars. I only found it with a torch. Bought a new rubber gasket and all good. Thought I would mention it just in case. The dealer told me they all tend to go around that age if disturbed.
- Stu
- Has liked: 622 times
- Been liked: 607 times
I must admit I do like these bars and I am tempted to do the conversion myself
My worry is the view out of the mirrors!
I don't want to go down the route of additional mirrors
- EasyRider
I did not use the oem mirrors once today when i was out.
I'm going to cover them up with some vinyl wrap.
So if you dont want mirrors on the bars, dont do the swap.
ps. i dont know if not having the bar risers would make using the oem mirrors better.
But i wanted the handlebars raised.
- Has liked: 634 times
- Been liked: 107 times
- Stu
- Has liked: 7 times
- Been liked: 2 times
I need to replace the silent blocks at the top of the suspension because the right side has some play. To do that, I need to remove the top yoke. I'd like to understand how I can remove the bottom nut without dismantling the fairings.
Can someone tell me?
