Fairing Tab Repair?
Has liked: 123 times
Been liked: 98 times
Fairing Tab Repair?
I just had the 2 plastic tabs on my right front side fairing pannel break. Other than buying a new pannel I am looking for a good secure fix for repairing the tabs. YouTube has several. Some don't look too strong. Anyone have a method that worked for you?
exportman
Has liked: 16 times
Been liked: 75 times
Re: Fairing Tab Repair?
Post by exportman »
Hello
I found some stainless picture hooks that stuck on the back of the panels cant remember where from now it was on my previous RT
Have a look here Randy.
viewtopic.php?t=6173
Do not rely on the double sided pads that come with them,mine melted in Spain and I had to bodge them to get home.Reinforce them like I did,they held on great after :thumb:
You can make them yourself and save the money,but your not going to have to pay the price i did.
Hope it helps.
Thanks, I like the Clearwaterlights concept, I may buy one and try fabricating the other. :thumb:
mikeromo73
Post by mikeromo73 »
I used the Clearwater lights repair kit to fix mine and just found the double stick foam tape had come unstuck from the panel. I will remove and go back and "bodge" them with epoxy and fiberglass tape to reinforce them. I definitely like the way the panel goes back to looking normal and keeping the on/off process the same.
Has liked: 96 times
Been liked: 141 times
Post by Sullivj »
I recently used this JB WELD PLASTICWELD on my Triumph fairing. You cut off a slice of putty and mix it with the integrated hardener. I formed a small doughtnut around a fibre washer to strengthen the repair.
You have about 15 mins to work with it before it starts to harden. After 24 hours, it's rock hard.
https://www.jbweld.co.uk/copy-of-kwikwoodep-2
I fabricated a solution. I bent some 20 ga. stainless steel into a suitable shape and JB welded pieces to the pannel. They are strong and everything fits like stock. Here are some photos.
Sketch
Sketch
Top View
Top View
Side view
Side view
Glued in place
Glued in place
Installed- top
Installed- top
Pannel instaulled 1
Pannel instaulled 1
Bending Fixture
Bending Fixture
Cracking job you've done there. God loves a bodger.
Has liked: 96 times
Post by Sullivj »
Nice work. That JB is good stuff, albeit it STINKS when you mix it.
