Motobatt MHTX16
Been liked: 258 times
Motobatt MHTX16
Does anyone have a Motobatt MHTX16 hybrid battery fitted rated at CCA340, if so how does it perform?
My 1250 occasionally fails to restart after a short ride (10 miles) the TFT resets, leave it for 20 minutes and it will start again as if nothing has happened. This happens with a fully charged Yuasa YTX16-BS that is approx 1 year old now, but was the same 6 months ago, all connections have been cleaned and tightened.
On starting the voltage drops from 12.3 to 11.6v then climbs to 14.4v with the engine idling
Re: Motobatt MHTX16
Yes. Coincided with my battery letting me down twice,
Replacement is easy, same dimensions.
As you see I also added the pigtail so that I could jumpstart it directly and easily from a NOCO unit.
viewtopic.php?p=84169&hilit=Motobatt#p84169
