Footrest lowering
Oldmansteve
- Bike Model and Year: BMW 1200rt 2014
- Has liked: 4 times
Footrest lowering
Hi has anyone tried the rider footrest lowering kit from AliExpress or Amazon. Are they any good
- Has liked: 1695 times
- Been liked: 549 times
Re: Footrest lowering
Ive Aliexpress on my RT. They work without any fitting problems
- Steve398
- Has liked: 584 times
- Been liked: 490 times
Except for the spring replacement, which was a copper-plated pig to put on.Doctor T wrote: Wed May 20, 2026 2:18 pm Ive Aliexpress on my RT. They work without any fitting problems
- Been liked: 560 times
I had Chinese lowering on me 16 plate RT,fitted spot on,no issues and a very good finish.
- Has liked: 123 times
- Been liked: 98 times
Me too, No difficult problems.You may want to enlarge your brake and shift control levers/pedals. Just about all the lowering kits move the pegs further out and those pedals feel like they get smaller
MarkW
- Bike Model and Year: R1200RT 2012
- Has liked: 1 time
- Been liked: 10 times
I've got a chinese set on my 2012 twincam. All works very well and has really helped my knees. Fitting was straightforward except for wrecking one of the original pins getting it out, so had to replace with a new one. They are very soft stainless steel - heat was required.
- Has liked: 35 times
- Been liked: 183 times
There's a trick to the spring. Put a screwdriver through the center of the spring and slide.Steve398 wrote: Wed May 20, 2026 6:52 pm Except for the spring replacement, which was a copper-plated pig to put on.
My kit, as i said, came from China, but the destruction was a copy of Wundelic with the name blanked out. This was the same with the f & R crash bars i bought.
Makes you wonder where these expensive parts are really made. I've had the same brake levers, sat nat mountings etc
